What does this connector go to?
I pulled my throttle body to rebuild it since I'm in the middle of getting my new Comanche running and driving and noticed a connector that is not connected.  It is behind the throttle body almost under the intake.  I pulled it up for the picture.  I couldn't see anything that it would have been connected to.  This truck does have AC but the compressor is not there so I'm not sure if that has anything to do with it.
EDIT: It's the connector at the bottom of the pic.
I see, you didn't specify which connector, I just assumed the one closest to the camera. The bottom is for an automatic, if you have a standard, cap it and forget it.
This^^. The square connector of the TPS is only used on automatic transmission equipped models.
