JasonB Posted February 15, 2016 Posted February 15, 2016 How difficult would it be to swap my slushbox AW4 for a 5 spd manual tranny? What all is involved? My last trail rig was a 5 spd Toyota with a Marlin crawler doubler sitting on 35's with 5.29 gearing. I haven't wheeled my Comanche yet as I've been trying get it "right" before hitting the trail. My setup now is Ford Dana 44 front and 9 in in rear with spools and 5.13 gearing sitting on 36's. My concern is that once I go wheeling with it I'll be disappointed in the gearing or lack thereof and I just prefer wheeling with a manual shift. Any suggestions or advice would be appreciated.
JasonB Posted February 16, 2016 Author Posted February 16, 2016 Also is it possible to find a wrecked 2003-2006 Rubicon and use the NV3550 or the NSG370 with the Rock Trac 4:1 tcase? Can this work mounted up to a Renix engine in a 88 Comanche?
Pete M Posted February 17, 2016 Posted February 17, 2016 don't know if it's the only hiccup, but one of the late-late model trannys have a completely different location for their CPS so you'll need to mill a spot in the bellhousing for the 88's. there's an auto-to-manual thread here: http://comancheclub.com/topic/48710-diy-projects-writeups-master-search-index/
88whitemanche Posted February 17, 2016 Posted February 17, 2016 Nv3550 can fit on your Comanche... 1 member has done it here...
JasonB Posted February 18, 2016 Author Posted February 18, 2016 how does the nv3550 differ from the ax-15 in strength? would the cost be worth it to go with a nv3550? and would a rock trac mount up to the ax-15? I know the nv3550 and the nsg370 would mount straight up to the rock trac but would those trannies mount up to the old remix motor? thanks for the help. just trying to figure out all my possibilities.
JasonB Posted February 18, 2016 Author Posted February 18, 2016 Pete, that link above is very informative. Thanks. It's like the Bible for the Comanche lol
88whitemanche Posted February 18, 2016 Posted February 18, 2016 how does the nv3550 differ from the ax-15 in strength? would the cost be worth it to go with a nv3550? and would a rock trac mount up to the ax-15? I know the nv3550 and the nsg370 would mount straight up to the rock trac but would those trannies mount up to the old remix motor? thanks for the help. just trying to figure out all my possibilities. The differences is not that much between the nv3550 and ax15...it's all really what you can get your hands on... The rock trac transfer case should fit on the nv3550 and ax15... Not too sure about the nsg370...you can google and try your luck....for swap and transfer case
