ParkRanger397 Posted January 29, 2016 Posted January 29, 2016 Hey, I'm new to this. How do I start a new forum?
Eagle Posted January 29, 2016 Posted January 29, 2016 Sometimes those simple things slip my mind. Well in that case a metric ton factory leaf spring will have a 3/4 inch lower ride height then a non metric ton. No, it won't. It has less unloaded arch, but it's a stiffer/stronger spring, so the weight of the unloaded chassis and box don't deflect the springs as much as the standard springs.
Pete M Posted January 29, 2016 Posted January 29, 2016 Hey, I'm new to this. How do I start a new forum? do you mean a new thread? should be able to by clicking the "start new topic" box in the upper right corner of any of the forum pages. unless you mean the classifieds, for which you'll need 10 posts in other areas first.
NorthWoods Posted January 29, 2016 Author Posted January 29, 2016 Thank you eagle for the explanation of that. I don't want to give someone bad info. I had just figured it out mathmatically.
87mjdriver Posted February 10, 2016 Posted February 10, 2016 OK I just got done swapping springs, In a SOA configuration I took out my hell creek metric ton leaves and put in general springs standard 3+1. I lost 2 inches in lift. If anyone in the MN area wants a set of metric ton leaves I have some for sale
