Bob Posted January 7, 2016 Posted January 7, 2016 Vin number : 1J7FJ26S9ML534692 1991 Jeep Comanche 1 ton long bedEngine : 4.0 Liter Inline 6 cylinder gas Stock Transmission : Colum shift Automatic (AISIN AW-4) Stock Tranfercase : New Process (NP 231) Stock Front Axle : Dana 30 with vacuum actuator Stock Rear Axle : Dana 44 w/ sway bar Stock Wheelbase : Unknown Build date : Unknown Location : Puget Sound - Washington State – Bellevue - 98007 Bought from Pick-N-Pull $500.00 Truck - Started, Drivable, Crashed (Front passenger side) GVW : 3034 lb Value code : $12484.00 Model : CMH Style: PK Odometer : 249xxx miles on cluster - Title say Code “E” mileage=000xxx Issues : Bent front bumper (and broken little vacuum ball) (black) Front Quarter Panel (missing badge green fiberglass) Grill (8 slot) (black) Front Fascia (green fiberglass) Rear bed (driver side behind wheel well)(green) Bench seat torn (beige 3 seat belts 2 missing) Cracked windshield No radio (after market speaker in doors) 4x4 not engaging Manifold making noise (broke/leaking) Oil dripping from valve covers / rear pinion gear Water leaking from radiator (cap/ hoses) Power steering making whining noise (No fluid) End knob on column shift missing (chrome) Jeep logo plug missing on steering wheel (3 spoke aluminum) Rear bumper bent (w/2” ball / 4 pin trailer plug / black) Has no door window vents, hand crank glass cranks, stupid lights for instrument cluster Floor is black rubber, no jack, no tire hanger under bed, no spare, wipers work but Not go all the way down, lots of paint scratches, 4x4 badges missing, green exterior, Beige interior, very basic truck Headlights are some kind of HID w/ ballasts, low beams blue light, high bright white Flashers front and back, SlimLite DOT style, run manually off lighter socket plug in
JMO413 Posted May 25, 2019 Posted May 25, 2019 *D4 TRIM STYLE D4 - VINYL BENCH SEAT -Y6 DARK SAND 173 Zone 73-San Francisco 1AA U.S. Dealer Retail 4AF American Coin Merchandising ALA SE Decor Group APA Monotone Paint BAP 75 Amp Alternator BCX Nickel Metal Hydride Battery BGA Power Front Disc/Rear Drum Brakes CBA Straight Back Bench Seat CKJ Black Vinyl Floor Covering DGB All 4-Speed Automatic Transmissions DGS 4-Speed Automatic AW4 Transmission DHA Lock-Up Torque Converter DHN Command-Trac Part Time 4WD System DHT Elec,Shift-on-the-Fly,P/Time T/Case DJH 230MM Front Axle DMD 3.55 Rear Axle Ratio DRJ 175MM Rear Axle ERH 4.0L I6 Power Tech Engine GAC Tinted Glass Windows GBB Tinted Windshield Glass GCB Front Door Tinted Glass GEH Fixed Door Vent Glass GFD Rear Sliding Window GRV Left Manual Mirror GUA Open HCD Do Not Use - See HCA JAZ DO NOT USE - See JP, KA classes JCA 85 MPH Primary Speedometer K3Z STRIPE/BADGE/MOLDING/COLOR KWW ST-DCL WHT "STLT R/T" LBC Glove Box Lamp LMA Halogen Headlamps MB1 Black Front Bumper MDA Front License Plate Bracket MFF Black Grille MHB Bright Windshield Moldings MMC Rear Door Solid Window Insert MMG Belt Moldings MMJ DRIP TROUGH MOLDINGS - TYPE I NAE California Emissions NBK EVAP Control System NF5 Fuel Tank - 23 Gallon PG5 Hunter Green Metallic QG5 Hunter Green Metallic Clear Coat RA8 Delete Radio SBA Power Rack and Pinion Steering SCE Alcantara Wrap Steering Wheel SFA Standard Duty Shock Absorbers SGA Rear Shock Absorbers TBC Compact Spare Tire TBM Tire Carrier Winch TPF P205/75R15 BSW All Season Tires TZH Michelin Brand Tires WJK 15X6.0 Styled Steel Wheels WLY All Steel Wheels XBS Pickup Box YAA Build To U.S. Mkt. Specifications YGE 5 Additional Gallons of Gas Z01 Rear Spring Group I Z5A GVW/Payload Rating Z66 Left Front Group XV Z85 Right Front Spring Group XIV Body Model JL62 Build Date 10/9/90
jdog Posted February 1, 2021 Posted February 1, 2021 Selling Dealer: EXPRESSWAY JEEP-EAGLE INC San Jose, CA
