Bob
    Bellevue WA
693 profile views
Bob's Achievements
  1. Bob
    1J7FJ26S9ML534692
    Vin number : 1J7FJ26S9ML534692 1991 Jeep Comanche 1 ton long bed Engine : 4.0 Liter Inline 6 cylinder gas Stock Transmission : Colum shift Automatic (AISIN AW-4) Stock Tranfercase : New Process (NP 231) Stock Front Axle : Dana 30 with vacuum actuator Stock Rear Axle : Dana 44 w/ sway bar Stock Wheelbase : Unknown Build date : Unknown Location : Puget Sound - Washington State – Bellevue - 98007 Bought from Pick-N-Pull $500.00 Truck - Started, Drivable, Crashed (Front passenger side) GVW : 3034 lb Value code : $12484.00 Model : CMH Style: PK Odometer : 249xxx miles on cluster - Title say Code ā€œEā€ mileage=000xxx Issues : Bent front bumper (and broken little vacuum ball) (black) Front Quarter Panel (missing badge green fiberglass) Grill (8 slot) (black) Front Fascia (green fiberglass) Rear bed (driver side behind wheel well)(green) Bench seat torn (beige 3 seat belts 2 missing) Cracked windshield No radio (after market speaker in doors) 4x4 not engaging Manifold making noise (broke/leaking) Oil dripping from valve covers / rear pinion gear Water leaking from radiator (cap/ hoses) Power steering making whining noise (No fluid) End knob on column shift missing (chrome) Jeep logo plug missing on steering wheel (3 spoke aluminum) Rear bumper bent (w/2ā€ ball / 4 pin trailer plug / black) Has no door window vents, hand crank glass cranks, stupid lights for instrument cluster Floor is black rubber, no jack, no tire hanger under bed, no spare, wipers work but Not go all the way down, lots of paint scratches, 4x4 badges missing, green exterior, Beige interior, very basic truck Headlights are some kind of HID w/ ballasts, low beams blue light, high bright white Flashers front and back, SlimLite DOT style, run manually off lighter socket plug in
