1J7FJ26S9ML534692
Bob
Vin number :      1J7FJ26S9ML534692
1991 Jeep Comanche  1 ton long bed
Engine :                4.0 Liter Inline 6 cylinder gas                        Stock
Transmission :   Colum shift Automatic (AISIN AW-4)           Stock
Tranfercase :      New Process (NP 231)                                    Stock
Front Axle :         Dana 30 with vacuum actuator                    Stock
Rear Axle :          Dana 44 w/ sway bar                                      Stock
Wheelbase :       Unknown
Build date :         Unknown
Location :             Puget Sound - Washington State – Bellevue - 98007
Bought from Pick-N-Pull $500.00 Truck - Started, Drivable, Crashed (Front passenger side)
GVW : 3034 lb    Value code :  $12484.00                 Model : CMH                     Style: PK
Odometer : 249xxx miles on cluster - Title say Code “E” mileage=000xxx
                Issues :                                 Bent front bumper (and broken little vacuum ball) (black)
                Front Quarter Panel          (missing badge green fiberglass)
Grill        (8 slot) (black)
Front Fascia                                                        (green fiberglass)
Rear bed                     (driver side behind wheel well)(green)
Bench seat torn                          (beige 3 seat belts 2 missing)
Cracked windshield
No radio                                     (after market speaker in doors)
4x4 not engaging
Manifold making noise                                         (broke/leaking)
Oil dripping from valve covers / rear pinion gear
Water leaking from radiator                                     (cap/ hoses)
Power steering making whining noise                       (No fluid)
End knob on column shift missing                                 (chrome)
Jeep logo plug missing on steering wheel (3 spoke aluminum)
Rear bumper bent           (w/2” ball / 4 pin trailer plug / black)
Has no door window vents, hand crank glass cranks, stupid lights for instrument cluster
Floor is black rubber, no jack, no tire hanger under bed, no spare, wipers work but
Not go all the way down, lots of paint scratches, 4x4 badges missing, green exterior,
Beige interior,  very basic truck
Headlights are some kind of HID w/ ballasts, low beams blue light, high bright white
Flashers front and back, SlimLite DOT style, run manually off lighter socket plug in
  • 3 years later...
*D4 TRIM STYLE D4 - VINYL BENCH SEAT
-Y6 DARK SAND
173 Zone 73-San Francisco
1AA U.S. Dealer Retail
4AF American Coin Merchandising
ALA SE Decor Group
APA Monotone Paint
BAP 75 Amp Alternator
BCX Nickel Metal Hydride Battery
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
DGB All 4-Speed Automatic Transmissions
DGS 4-Speed Automatic AW4 Transmission
DHA Lock-Up Torque Converter
DHN Command-Trac Part Time 4WD System
DHT Elec,Shift-on-the-Fly,P/Time T/Case
DJH 230MM Front Axle
DMD 3.55 Rear Axle Ratio
DRJ 175MM Rear Axle
ERH 4.0L I6 Power Tech Engine
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GFD Rear Sliding Window
GRV Left Manual Mirror
GUA Open
HCD Do Not Use - See HCA
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
K3Z STRIPE/BADGE/MOLDING/COLOR
KWW ST-DCL WHT "STLT R/T"
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MDA Front License Plate Bracket
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAE California Emissions
NBK EVAP Control System
NF5 Fuel Tank - 23 Gallon
PG5 Hunter Green Metallic
QG5 Hunter Green Metallic Clear Coat
RA8 Delete Radio
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TBC Compact Spare Tire
TBM Tire Carrier Winch
TPF P205/75R15 BSW All Season Tires
TZH Michelin Brand Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z5A GVW/Payload Rating
Z66 Left Front Group XV
Z85 Right Front Spring Group XIV
Body  Model JL62
Build Date 10/9/90
  • 1 year later...
