Area51Werks Posted December 11, 2015 Posted December 11, 2015 I'm searching for the rear tail light harness connection. Left side rear under the box. It is an oval shaped plug. I searched a local yard but they didn't have a 91 or newer Comanche. The older trucks have a square plug. The Cherokees are not the same oval shape either. Looking for someone with several 91 or newer parts trucks that would cut this plug out for me. http://comancheclub.com/topic/48897-wtb-tail-light-harness-plug/
HOrnbrod Posted December 11, 2015 Posted December 11, 2015 That's a 6-pin connector and only five wires are used. According to my parts manual the same connector is used on the 91 XJs. If you are unsuccessful finding the exact connector, you can splice in a male / female 5 or 6 pin weather pack or similar connector set.
mnkyboy Posted December 11, 2015 Posted December 11, 2015 There is a guy on the Comanche Facebook groups that deals in MJ parts.
Area51Werks Posted December 12, 2015 Author Posted December 12, 2015 I'm looking for the actual oval shape plug. I'm trying to make a plug and play trailer connection.
JH4020 Posted December 12, 2015 Posted December 12, 2015 Seems like I have seen a plug-n-play harness on Ebay lately!
tugalo Posted December 12, 2015 Posted December 12, 2015 most of the connectors on Mj's are Weatherpak. You can find them on ebay................
daking Posted December 12, 2015 Posted December 12, 2015 I know this is little help: I ended up making my own tail light harness using GM weather pack fittings. I wired in a 7 pin trailer connector too. I put fuses and even used relays to power the LED backup lights. Much cleaner and heavy duty setup, over the stock wiring. But just using weather pack connectors, you will find it better. I "think" i have the connector you want. I'll need to dig in the pile of parts I removed. If I have it, I'll send it to you for free. I'll PM you with a picture, if I find it.
Area51Werks Posted December 14, 2015 Author Posted December 14, 2015 I know this is little help: I ended up making my own tail light harness using GM weather pack fittings. I wired in a 7 pin trailer connector too. I put fuses and even used relays to power the LED backup lights. Much cleaner and heavy duty setup, over the stock wiring. But just using weather pack connectors, you will find it better. I "think" i have the connector you want. I'll need to dig in the pile of parts I removed. If I have it, I'll send it to you for free. I'll PM you with a picture, if I find it. Thanks! I'll send you a PM as a reminder.
