Garrett Posted October 23, 2015 Share Posted October 23, 2015 Recently replaced slave cylinder on my peugot ba10/5, filled up and bled but no pressure in pedal. Any ideas? Thinking about putting old one back in. Link to comment Share on other sites More sharing options...
Eagle Posted October 23, 2015 Share Posted October 23, 2015 No fluid leaking out? Bleed it some more. Link to comment Share on other sites More sharing options...
Garrett Posted October 23, 2015 Author Share Posted October 23, 2015 I have a solid stream pushing out Link to comment Share on other sites More sharing options...
yxmj Posted October 23, 2015 Share Posted October 23, 2015 tighten the bleed screw....take the top off the reservoir....press the pedal...while looking in the reservoir.....any bubbles? Link to comment Share on other sites More sharing options...
Garrett Posted October 23, 2015 Author Share Posted October 23, 2015 I did as i was pumping yesterday , didnt see any. Link to comment Share on other sites More sharing options...
4.0forlife Posted October 24, 2015 Share Posted October 24, 2015 Did you try leaving it in gear and trying to start it with the clutch pedal pressed in. Disconnect the coil wire Before you try though. It my feel softer but work fine. My 03 ram did the same thing when I did the slave cylinder. Hope this helps Link to comment Share on other sites More sharing options...
metrictonner Posted October 24, 2015 Share Posted October 24, 2015 New throwout bearings are almost impossible to bleed if you didn't follow the installation proceedures: Don't touch the throwout bearing compression straps or clutch pedal until you have filled the master cylinder and done the first bleed, then, with a full master cylinder, press in on the clutch pedal for the first time and refill master cylinder. To save the day you will probably have to open up the bell housing, reattach the compression straps and start all over again. How do you bleed the thing without stepping on the clutch? With a small hand vacuum pump brake bleeder. Link to comment Share on other sites More sharing options...
Garrett Posted October 25, 2015 Author Share Posted October 25, 2015 I got it figured out, bleeding it wrong. guess the way i ve been bleeding had been wrong. Thanks for the advice guys. Link to comment Share on other sites More sharing options...
