Who knows what this vacuum line goes to?
There is a pale vacuum line under the water bottle... It comes through the firewall. It is right above the black that the AC lines go through before going through the firewall.
Mine is dangling and dryrotted.
Can anyone tell me what it is and where it connects so I can run a new line?
Thanks.
Rev. Toid
what does the valve do?
I'll have to check mine out to see if it's there. I can't say if it is.
It stops the flow of coolant through the heater core when vent or AC is selected.
Oh, and the thing it's mostly noted for:
Disintegrating at the most inopportune time and causing a huge coolant loss.
Eliminate it. There is no downside.
Cruiser,
This thread got me curious to check and I see that I now have it with everything still connected. How do I bypass and how could a failure result in losing coolant? From where does the coolant flow out if the valve fails?
Thanks
Cruiser,
Thanks
Those plastic valves just split and spray tons of coolant out. Remove it and put a straight piece of pipe or a splice in it.
Actually, on the 94 HVAC that I put in my comanche, it only shuts off the coolant when you slide the selector to the off position. I want it off in vent too, but it doesn't do that. I'd agree there's no reason not to remove it.
