Not much to go on. Does it not move, or does it just struggle to do so?
When was the last time you checked the trans fluid?
Have you tried unplugging the trans computer to shift manually?
Agreed.
Could be a blown/corroded fuse to the TCU.
Sorry for no responses to the help. Jeep is in Oregon, I am in Mass. Work schedules and time difference will delay any work until weekends
Trans fluid is clean and full
All grounds removed and cleaned
Have not tried driving in low because the engine is now running very rough
I am waiting on results of fuel pressure test
EGR is clean and working
Plugs are new
To check the tranny, the FSM instructs us to remove the TCU fuse and shift manually. When driven that way you lose one of the two low gears when in the "Lo" position -- second gear, IIRC -- but otherwise you should be able to drive it by shifting manually. This is to diagnose whether the problem is a transmission problem or a TCU problem.
You also want to be sure the shift linkage is properly adjusted. That's why I asked if it runs in the "Lo" position.
