87' Transmission Rattle
I have a mean rattle from the transmission (I think) in my 87' 2.5L 4WD. Sounds like a couple of screws in a blender. The sound is present at all times, but if I let the truck idle, then rev up the motor, the sound dissapears just before it returns to idle...then comes back. Replaced the entire clutch assembly a couple years ago, including the throwout bearing, and did the internal slave earlier this summer (for the third time). Truck shifts and drives great, except there is a heavy hum/vibration in the dash when decelerating - not sure if that is related. Tranny fluid was almost a quart low when I checked/ refilled today. I have basically ruled out exhaust rattle. Help me Obi Wan Kenobi...
Thanks guys, I checked the transmission mount, and while it looks like the rubber is separating a bit, the noise doesn't seem to be coming from there. I combed over the entire exhaust while the truck was running and again found nothing. Next I'll check the motor mounts - where exactly are they located?
