big66440 Posted September 23, 2015 Share Posted September 23, 2015 Since i recently began completely overhauling my AC system I was wondering if there is a way to upgrade the system using parts off of newer XJ's or other Jeeps? I've been having a hard time finding some of the parts and if I can use parts off newer vehicles to make the replacement parts easier in the future ( I'm not getting rid of my MJ anytime soon) or to make the system work better id be really interested in going that route, thanks in advance. Link to comment Share on other sites More sharing options...
Crash Posted September 23, 2015 Share Posted September 23, 2015 Well, you will need to run R134a as R12 is pretty much non existent. Pretty sure most of the components from the later model XJ will work. To run the later model compressor, you will need to run a later model AC/fan bracket. Some of your local parts stores should have the ability to modify/make lines for you if necessary. Link to comment Share on other sites More sharing options...
Heavy Metal Posted September 23, 2015 Share Posted September 23, 2015 I am in the process of replacing everything except the compressor and the evaporator in my MJ and I will be charging it with R-152a, better known as dust-off (difluoroethane). I will tell you how it goes. But, you can read through an SAE powerpoint presentation on it here. Link to comment Share on other sites More sharing options...
mikekaz1 Posted September 23, 2015 Share Posted September 23, 2015 there is a propane based r12a refrigerant that you can get. Link to comment Share on other sites More sharing options...
gogmorgo Posted September 24, 2015 Share Posted September 24, 2015 I would only use r12a to recharge an older working system. It's not the best refrigerant out there, it just happens to be inert and effective enough to behave well with whatever is already in your system. If you're changing components anyhow, might as well upgrade to a modern refrigerant. Link to comment Share on other sites More sharing options...
