Another AX15 problem
You've gotta get the angle of the dangle just right for the input shaft to slide into the pilot bushing/bearing.  I actually had a harder time getting the dowels for the bellhousing to line up correctly.  Are you sure that isn't your problem?
I've had to lower the trans and loosen the pressure plate several times to make sure the input shaft will line up.
My suggestion for you is to check the alignment of the pressure plate before you tighten the bolts on it  :doh: .  I have had to undo them to get things to line up correctly.
