So for about 3 months now Ive had a ford 8.8 ready to swap in including a new 5.5 inch lift.  :doh:I have everything to do the lift and swap and i know how to do it, but i haven't yet because its different gearing then my dana 30 upfront right now and i need a drivable car and 4wd here in the upcoming colder months. But now that i have this 1995 4wd cherokee with a non CAD dana 30, I'm going to pull it out and have it re geared and put that in my comanche. I'm not going to build it up yet because i don't have the money because i started school and can't work as much, but i just want to replace what i should and get the parts to re-gear it. I'm just wondering what i need to buy for a re gearing? thanks. Id like to get the parts so that i can do this ford 8.8 swap, new 5.5 alexia lift and then this dana 30 all in one weekend.
BTW I'm not doing it myself, but i just want to have all the parts ready to bring to the shop. also, the shop in town here is cool with bringing in your own parts.  . :MJ 1: . (me after swap)
What gear ratio is in the xj d30? 8.8 is 4.10 right?
http://eastcoastgearsupply.com/i-16502363-yukon-dana-30-reverse-hp-4-10-ring-pinion.html
http://eastcoastgearsupply.com/i-126965-dana-30-reverse-cjinstall-kit-master.html
That's basically all you need, Unless the current gears in the d30 are really low, Then you'll need a different carrier.
I'm not sure what they are because the tabs are gone. And ya the 8.8 is 4.10s
BTW how's the exo cage? I think I might build something like ryansatrocks one. I have all the tools and I've help build one so I think I might give it a whirl in the near future
Spin the tire once, Count how many times the pinion spins.
IIRC 3.73 & Above is the carrier you need.
3.55 & below is the wrong carrier
Cage is coming along nicely, Got 90% of the front cut out & tack welded together. Tomorrow we should finish the whole front cage, Probably take it off & completely weld it too.
Other then that is it a direct swap over? Also, because I no longer need the vaccum because of my ax15 t case, can I just take it all out?
