My AX15 Swap
Also, I haven't done it yet but is the linkage a direct swap over? I have everything else done but I didn't have time to put in the linkage
Yes, but....
I had to lift the carpeting to get the bolts that hold the bracket to the trans tunnel.  That means removing the driver's seat (bucket).
FWIW, I always remove the CPS before I remove or install a tranny. This insures the CPS will not get damaged from the flywheel during the swap.
I had not thought about that.  I hope I did not damage it
How come the new bushing looks a bit beat up?
I had to use an old sparkplug socket to drive it it.   :roll:
After some fiddling with final parts (like the tcase vent tube  :doh: ) I've got it all back together.   :banana:
I drove it around the block to test it out.  The clutch feels great.  Nice and firm.  The shifting is stiffer than the BA, but has a much shorter throw.
