Egm89 Posted July 23, 2015 Share Posted July 23, 2015 1987 4.0 2wd swb I have done some research about the location of it, but it seems that mine doesnt have it. Adding a picture for reference. Link to comment Share on other sites More sharing options...
rearview Posted July 23, 2015 Share Posted July 23, 2015 The dipstick ground is the bolt that mounts the dipstick tube to the engine block. Follow the oil tube to a two sided bolt. Link to comment Share on other sites More sharing options...
Egm89 Posted July 23, 2015 Author Share Posted July 23, 2015 Going to check it out now. Uploading some more pictures tomorrow Link to comment Share on other sites More sharing options...
cruiser54 Posted July 23, 2015 Share Posted July 23, 2015 Image Not Found Link to comment Share on other sites More sharing options...
ParadiseMJ Posted July 23, 2015 Share Posted July 23, 2015 I found yours by following the battery ground cable in the first picture. OP, you might want to clean things up down there. It'll make things a lot easier to find. Link to comment Share on other sites More sharing options...
Egm89 Posted July 23, 2015 Author Share Posted July 23, 2015 On the white circle its my dipstick location, and thats were it connects to te engine block. And on the circle its my battery cable so, my ground would be on the battery cable then? I found yours by following the battery ground cable in the first picture. OP, you might want to clean things up down there. It'll make things a lot easier to find. I'm on it, but first doing all the cruisers tips, bte i just bought this truck last week haha Image Not FoundWhy is my setup different cruiser? Link to comment Share on other sites More sharing options...
ParadiseMJ Posted July 26, 2015 Share Posted July 26, 2015 The white circle is indeed where the dipstick enters the block. The bolt that holds the upper part of the stick tube to the block is where the ground is. Look further up. Link to comment Share on other sites More sharing options...
Egm89 Posted July 27, 2015 Author Share Posted July 27, 2015 The white circle is indeed where the dipstick enters the block. The bolt that holds the upper part of the stick tube to the block is where the ground is. Look further up. I'm starting to think mine doesnt have one Link to comment Share on other sites More sharing options...
ParadiseMJ Posted July 27, 2015 Share Posted July 27, 2015 I tried to put some arrows here. [/url The fatter arrow towards the bottom is your battery ground cable. Follow that towards your block, behind the heater valve... The battery ground cable should end at the block (under all the grease) where the little skinny arrows are. If you DON'T have a ground...your Jeep is not running. A flashlight and some neck bending may be required. Link to comment Share on other sites More sharing options...
Egm89 Posted July 27, 2015 Author Share Posted July 27, 2015 I only saw that. But I think thats the one for the battery. I'm going to try to clean it first so I can find that ground. That may explain alot of problems that I have. Thanks ParadiseMJ, uploading more pics with what I can find soon. Link to comment Share on other sites More sharing options...
