dustyinthedirt Posted July 19, 2015 Posted July 19, 2015 the illumination on my cluster hasnt worked since i put the new cd player in. i figure i forgot a wire on the cd player since the past owner cut the harness out and i had to straight wire it in. but i don't see a wire i missed. also when i press the brake the right turn signal lights up on the dash. and on the front of the truck. this has been happening since before i got the jeep. its doesnt flash just illuminates the little arrow and the marker lights. not sure how to fix that ether. any help would be greatly appreciated.
Eagle Posted July 19, 2015 Posted July 19, 2015 The headlight switch rotates to dim the dash (gauge) lights. I don't remember which way, but all the way in one direction turns them off completely. If they're all out I would look to that, or consider a bad headlight switch, because there are something like 6 or 8 individual bulbs in there, and it would be extremely unlikely they'd all be burned out at once.
shelbyluvv Posted July 19, 2015 Posted July 19, 2015 Could be a fuse as well. The turn signal ghost lighting is probably corrosion in the sockets or a bad ground.
Eagle Posted July 19, 2015 Posted July 19, 2015 Could be a fuse as well. True. I never think about the fuse because I've never had a dash light fuse go out on me, but I have had the rheostat in the headlight switch go bad a few times.
dustyinthedirt Posted July 19, 2015 Author Posted July 19, 2015 i will check these this evening when i get home. thanks guys
