Jeepjeff859 Posted July 16, 2015 Posted July 16, 2015 ok so today i got my clutch kit and the only thing that doesnt fit is the pilot bearing. i ordered a 1993 clutch kit and its to big. i found the bearing at autozone but it doesnt include the sleeve for the bearing to be pressed into and then into the back of the engine. Does any know of a bearing i can order (.586 inside diameter i think because the one i got is .75) that will fit the sleeve for a 1994 engine ?
Jeepjeff859 Posted July 16, 2015 Author Posted July 16, 2015 something i just though about is..... is can i get the bearing without the sleeve and pound it into the second race on the back of the engine ?
Jeepjeff859 Posted July 16, 2015 Author Posted July 16, 2015 So I'm guess my problem is that I'm using a grand Cherokee engine because the 4 outta 6 bolts line up
88whitemanche Posted July 16, 2015 Posted July 16, 2015 Keep turning the flywheel until they all line up.... That happened to me when I did my ax15 swap... And I had to take off the flywheel to get the original pilot bearing out
Rockfrog Posted July 17, 2015 Posted July 17, 2015 Looks like you have an 89/90 era AX15 ... They had a smaller Pilot diameter vs the 92 and later which were .75" Pilot. Not sure what you need to do there, check advanced adapters for a bushing, I think they have one (was about $10 last I recall). I know a CJ V8 Pilot is used with pre 95 4.0s and a later AX15. But you are adapting the other way.
Jeepjeff859 Posted July 19, 2015 Author Posted July 19, 2015 http://www.advanceadapters.com/products/716120--pilot-bearing-590-id-x-1818-od/
