87 4.0L
did some research on here, couldn't get exact issue, but my truck at idle sounds like its cam'd running rough, the it will pick up and run fine, then back to rough, sometimes when i shift to drive or reverse it will stall, it will start fine though. MAP sensor is ok, undo the vac line and it stalls, but when i unplug the idle air control valve no change, wondering if thats the issue?
done, and this issue is on the 87 4.0 guess that makes it easier for everyone huh, lol. forgot to do that :doh:
I have done some. As of today it has gotten worse, my gf said it had stalled on her while driving around 10-15mph it has never done that to me, I'm doing a tune up tomorrow on it, after that give ill give an update.
just thought when I unplugged that idle air control valve I would have noticed a change.
You could clean up the TB passage for the IAC, it may be plugged up causing you to notice no change.  I would also check/test the O2 sensor, as some of your symptoms are similar to those with a bad O2
makes sense because I just did the valve cover mod for sucking oil into the air filter through the pcv system, could very well be oil film hindering a good signal
and my CAT is cleaned out has been for years, O2 woud have picked that up wouldn't
the tune up helped out a lot, although the dumbasses at AutoZone gave me autolite when I ORDERED NGK's, better then what I had but will replace soon.  drives good, idle still funky but going to do some more of cruiser's tips before I start throwing parts at it,
Posted (edited)
i had a new button,cap and wires. so i did plugs, air filter, oil change. today i did tip 1&2, did #26 valve cover mod a week ago. it still idles funky start it up idles fine, then rough back to fine and so on. this motor is new i put it in a few months ago its been running fine till recently. cannot remember what year cherokee it came out of but was around the same cuz its a renix. all i have done is replaced the starter and this has been happening not long after
Edited by Blaine
Do 3 through 5 and then let's revisit this as needed.
