Nate C Posted May 3, 2015 Share Posted May 3, 2015 I have a leak that appears to be coming from the front of the oil pan, what beside that would cause a leak in the front? Oil pump gasket maybe? The straight 6 looks like it slants to the back, so most leaks would accumulate there,.... this is clearly dripping up front though. I don't want to tear into the pan gasket to discover it's something else. Any thoughts/ ideas are appreciated. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted May 3, 2015 Share Posted May 3, 2015 Crankshaft seal... There's where mine is coming from on my XJ, best I can tell. Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 3, 2015 Share Posted May 3, 2015 Check your vent line before you tear into it....a plugged vent line causes the crank case to overpressure, forcing oil out wherever it can like oil seals, valve cover gaskets and air boxes. Link to comment Share on other sites More sharing options...
Nate C Posted May 4, 2015 Author Share Posted May 4, 2015 Thanks for the tips, where are the vent lines I'm looking for? Where in Montana are you? I spent some time in Bozeman when I was younger - fun town! Link to comment Share on other sites More sharing options...
64 Cheyenne Posted May 4, 2015 Share Posted May 4, 2015 Valve cover to intake, look for write up to increase line size. Is your air cleaner dry or saturated with oil? (another indication of an overpressure condition.) And I live in Charlo, about 50 mi north of Missoula on the Flathead Indian reservation, although I'm not flathead, I'm Cheyenne transplanted from Southeast MT. Link to comment Share on other sites More sharing options...
Nate C Posted May 5, 2015 Author Share Posted May 5, 2015 Checked out the vent lines and air box, looks clean; I like the idea of bigger lines though,.... looks like i'm doing some gasket replacing this weekend. You live in an awesome part of the country, you're lucky. I miss my time out West. Cool you're a real Native! My Great Grandma was half Abnaki, The State recognizes the tribe but the Feds don't - total BS. they played a huge roll in Northeast history. There are a few people of the Iroquois confederacy here too, but they're mostly in New York. Link to comment Share on other sites More sharing options...
ParadiseMJ Posted May 5, 2015 Share Posted May 5, 2015 Oil pan gasket, crank seal, front of valve cover gasket. If your need to replace the oil pan gasket, the timing chain cover gasket, and/or the valve cover gasket...you'll be money and time ahead buying the Fel-pro rubberized gaskets and not the cheap-o cork gaskets. Mine have never leaked after many years of service. They're more expensive but are the best I've come across. Disclaimer: I do not work for or have any interest in Fel-Pro or any company affiliated with Fel-Pro. Link to comment Share on other sites More sharing options...
ggcnash Posted May 5, 2015 Share Posted May 5, 2015 Oil pan gasket, crank seal, front of valve cover gasket. If your need to replace the oil pan gasket, the timing chain cover gasket, and/or the valve cover gasket...you'll be money and time ahead buying the Fel-pro rubberized gaskets and not the cheap-o cork gaskets. Mine have never leaked after many years of service. They're more expensive but are the best I've come across. Disclaimer: I do not work for or have any interest in Fel-Pro or any company affiliated with Fel-Pro. Paradise, did you use any RTV or other sealant along with the rubber gasket there have been conflicting comments on this just wondering the best way? Link to comment Share on other sites More sharing options...
ggcnash Posted May 5, 2015 Share Posted May 5, 2015 Specifically the oil pan? Srry Link to comment Share on other sites More sharing options...
