Engine stalls at idle when I remove the hose from the valve cover rubber grommet & manifold
1989 4.0 engine with 5 speed.  Engine started stalling recently when it comes to an idle, runs fine from 1000rpm and up.  In checking things I removed the rubber hose that runs from the valve cover grommet to the intake manifold and the engine runs, hook the hose back up and the engine quits.  Any suggestions?
