redwolf624 Posted April 6, 2015 Posted April 6, 2015 so i'm having an obsession with switches in my MJ and i only have 1 more free "switch spot" in my 86 dash, i was wondering what yall have done for switch panels to eliminate the non-used areas, suchs as the clock panel, ash tray, the vent below the hvac controls, :needpics: Redwolf
redwolf624 Posted April 6, 2015 Author Posted April 6, 2015 Image Not Found Image Not Found Image Not Found did you make that or buy it? Redwolf
Blue XJ Posted April 6, 2015 Posted April 6, 2015 I have the same switches as above, they are a perfect size to use in the stock switch location on the dash, next to the headlight switch and the cigarette lighter. They fit into the holes that the factory switches are in perfectly. The best place I have found to buy those switches is www.otrattw.com I have a switch panel that I made, it's bolts to my center console in the front, below the ash tray, I have 5 or 6 of them mounted in that. And I have my 3 ARB switches mounted rearward of the shifter, in the ash tray spot (ash tray for the 97+ center console) Image Not Found
jimoshel Posted April 6, 2015 Posted April 6, 2015 We all have our quirks. Mine is instrumentation. Did you ever see another MJ with a ASI (Air speed indicator) or altimeter mounted in the dash?
