1989 Eliminator Posted March 30, 2015 Posted March 30, 2015 MJ Model: 1989 Jeep MJ 4.0L 2WD Issue at hand: At lower speeds when turning, I notice a vibration coming from the front driver side wheel. Seems to be worse when turning and I can kinda feel it driving straight. What I have done: I have installed a 2" lift using coil spacers and chevy drop shackles. I did not get an adjustable track bar. This was done about 6 months ago. I then had a weird noise and vibration in the same tire so I thought it was my bearings. I replaced the bearings with new ones. The issue was still there so I thought it was because I didnt replace the one piece rotor at the same time. So, I replaced the rotor and with new bearings again. (I packed the bearings very well)... Seemed to help but issue was still there. When the truck is parked, and when I grab the top of the tire and shake it back and forth, I hear a clicking like something is loose. So I replaced my ball joints. Problem still there. Brake pads looked good and didnt have unusual wear. Would appreciate some insight.
CJ's MJ Posted April 1, 2015 Posted April 1, 2015 I'm far from being an expert on this but a few thoughts come to mind. Vibration can be coming from an unbalanced wheel. Worse when turning I would consider looking into tie rods maybe as well.
1989 Eliminator Posted April 1, 2015 Author Posted April 1, 2015 Appreciate the response. They are brand new tires and I just got an alignment. They would not be able to do the alignment if the tie rods were bad and I even asked them. I'm going to do my wheel bearings one more time.... with this grease press tool I bought: http://www.amazon.com/gp/product/B0002NYDYO/ref=od_aui_detailpages00?ie=UTF8&psc=1 I will letcha ya'll know when I'm done. :crossfingers: :wrench:
Eagle Posted April 1, 2015 Posted April 1, 2015 I'm far from being an expert on this but a few thoughts come to mind. Vibration can be coming from an unbalanced wheel. Worse when turning I would consider looking into tie rods maybe as well. Neither of these can create a grinding noise. In fact, generally neither creates any noise at all. Are the brake calipers free on the sliders? Did you by any chance replace one or both calipers, and possibly get the wrong caliper?
1989 Eliminator Posted April 2, 2015 Author Posted April 2, 2015 I did not replace my calipers. Just brake pads and rotors.I cleaned off the sliders with a wire brush wheel to get most of the roughness off. Then re-installed sliders with brake caliper grease.
CJ's MJ Posted April 2, 2015 Posted April 2, 2015 I didn't see the word grinding in the description of what was wrong. I saw weird noise. I do agree would not be either if it's a grinding sound. LOL
sloride Posted April 2, 2015 Posted April 2, 2015 Brake rotor dust shield bent rubbing on rotor? I had that happen.
1989 Eliminator Posted April 2, 2015 Author Posted April 2, 2015 Okay well I just got done repacking my bearings with the new tool I got and it worked fantastic. Re-installed the bearings, tightened the axle nut while spinning the rotor, bleed the brake fluid, and made sure the brake shield plate wasnt rubbing. I put the tire on without the caliper and wiggled the tire from the 12 and 6 position (top and bottom) and there was nothing. Solid. Then I took the tire off, put the caliper on, cleaned the sliders, re-greased them and put the tire back on. Drove the truck around and the noise is still there. When the truck is on the ground and I grab the top of the tire and shake, I feel something moving. Bad caliper? It might be the tire making the noise?
Eagle Posted April 2, 2015 Posted April 2, 2015 I didn't see the word grinding in the description of what was wrong. I saw weird noise. I do agree would not be either if it's a grinding sound. LOL Thread title!
1989 Eliminator Posted April 8, 2015 Author Posted April 8, 2015 Well, just to take out the idea of my caliper pins having too much oxidation on them and causing the caliper to not slide right, I put in new slider pins. Problem still exsits so I'm thinking its the tire somehow so I will try to get my tires rotating.
1989 Eliminator Posted April 16, 2015 Author Posted April 16, 2015 Just replaced my steering stabilizer and still no change in the issue.
gogmorgo Posted April 17, 2015 Posted April 17, 2015 Power steering pump/gearbox? They're both on the front driver's side, and would be affected by steering input.
