Help with why gas-gauge is not working?
Ground problems are rampents on jeeps. Try to find the ground connection to the frame, if I recall it's back near the DS rear taillight. The wire that caries the voltage is black and orange I beleive . You can find it running under the truck under the drivers side (DS)  running from front to back. Look for shorts in the wire also. turn the wire over checking for places it may have been rubbing on above it from the bottom of the bed.  The ceramic connection on the DS fenderwell is the voltage reduction point for the fuel tank current. It may be loose or corodid. or the ceramic is cracked. You may need to check your fuse for bad contact, simple replace it. Also look for wire deteration near look fuse box from the back of the master cylinder fluid that leacks down the back side of firewall. You can pull the speedometer and disconnect and very carefully clean the copper contacts wiith alcholle or electrical spray cleaner.
What I learned: The gauge-needle is moved by magnets driven by 1-ohm to 88-ohm(full-tank). Applied voltage... Watch the needle go ♬ up-and-down, up-and-down ♬. Cleaned terminals on sending-unit and applied dielectric-compound.  All is good in Désirée land again!
