Tommy Posted March 13, 2015 Posted March 13, 2015 I was finally trying to install my new front bumper and steering box spacer. I was having a really hard time holding the box in place and getting the bolts lined up and started so I had a friend come over to lend a set of hands. I crawled underneath to hold the box up while he started the bolts. Got one started, then moved to the second one. After a minute he says "wow, this is getting really tight and I still have a bit to go." So I stop and have him back it out and sure enough, totally cross threaded. I've seen some people say drill and tap for 1/2 inch bolts, but is there any reason not to drill through it and use a longer bolt with a nut? It's dark out now so I can't really picture it but I feel like there was room. Any thoughts? Thanks
Eagle Posted March 13, 2015 Posted March 13, 2015 Look closely at the ears on the box. Going from memory from the last time I changed a steering box, I doubt there's enough space to get a nut on there and properly tighten it. Remember, you also need a washer and a lock washer to be secure.
Jeep Driver Posted March 14, 2015 Posted March 14, 2015 If you cannot thread it by hand FIRST!..........stop and figure out why.
Tommy Posted March 14, 2015 Author Posted March 14, 2015 I didn't realize it was going on hard. I was laying on the ground holding the box up. My buddy isn't super mechanical. Ain't no biggy
Tommy Posted March 19, 2015 Author Posted March 19, 2015 I thought I'd post the conclusion of this one in case anybody else searches for similar. It was the lower forward one that stripped. I drilled it to 7/16 and used a 7/16x5 bolt with allegorist nut, luck washers, all that. This way I can tap it to 1/2 later if I want. The other two bolts are threaded into the box like usual.
