jvd Posted March 11, 2015 Posted March 11, 2015 Driving to work (now) suddenly hear a ticking coming from instrument panel. Slows down as speed slows and increases in speed with speed, stops when I stop. My guess is speedometer cable loose? It's not jumping around or anything and haven't had the dash apart. Did a quick search and paradisemj mentions loose cable but his tick went away as he drove faster. Just curious if anyone had similar, not going to be able to look into it till next week anyway.
ParadiseMJ Posted March 11, 2015 Posted March 11, 2015 I eventually replaced the cable. The end that attached to the transfer case was stripped/rounded out and not making good contact (and rounding it further). New cable fixed it.
HOrnbrod Posted March 11, 2015 Posted March 11, 2015 If you are referring to the 91 model in your signature you don't have a speedo cable - it's electronic. Sometimes a cracked exhaust manifold can sound like a ticking noise and it varies with engine RPM.
jvd Posted March 12, 2015 Author Posted March 12, 2015 Yep, referring to the 91 and that is disappointing news, thanks for the replies.
Zebvance Posted March 12, 2015 Posted March 12, 2015 I had a bad front driveshaft u joint that caused the same symptoms. Roll down your window and drive up against the wall of a building. The noise with bounce off the wall and become louder and more apparent. Might help to narrow down what it is....
Rockfrog Posted March 12, 2015 Posted March 12, 2015 My old worn out tcase linkage used to do the same thing, tied it together to test theory and the clicking stopped.
jvd Posted March 12, 2015 Author Posted March 12, 2015 It sounds like the turn signal has been left on, just a little louder. Tick about every 4 seconds when moving up to about 40mph then just about every 2 seconds when faster. Thanks for ideas to check out, hope to be able to troubleshoot it next week. Got to change the fuel pump in the 04 grand cherokee first.
