CJ's MJ Posted March 8, 2015 Author Share Posted March 8, 2015 Thanks. So I should look for a different front axle? Reading a lot of the guys say the 30 is trash. Link to comment Share on other sites More sharing options...
cruiser54 Posted March 8, 2015 Share Posted March 8, 2015 Thanks. So I should look for a different front axle? Reading a lot of the guys say the 30 is trash. No. Not necessarily at all. Check your gear ratios next. Link to comment Share on other sites More sharing options...
rustybottoms88 Posted March 8, 2015 Share Posted March 8, 2015 Thanks. So I should look for a different front axle? Reading a lot of the guys say the 30 is trash. If your not going any bigger in tire size It may be worth keeping around. Did you figure out your gear ratio? Link to comment Share on other sites More sharing options...
Incommando Posted March 8, 2015 Share Posted March 8, 2015 The high pinion Dana 30 is a decent axle for the MJ. There are simple upgrades to improve it. Probably the most bang for the buck is replacing the front axle shafts with ones with larger u-joints. As long as you are staying with 33" tires or so the the D30 is fine. Many people run up to 35" tires with them. Link to comment Share on other sites More sharing options...
CJ's MJ Posted March 8, 2015 Author Share Posted March 8, 2015 I am doing the gear ratio now. It was raining earlier so couldn't do it earlier in the day. Link to comment Share on other sites More sharing options...
Rockfrog Posted March 9, 2015 Share Posted March 9, 2015 I run 35's on my 30, does fine. The biggest issue with the 30 is housing flex. A full case locker/LSD and a good differential cover will solve a fair bit of that. Otherwise a simple truss goes a long way if you plan to beat on it. The larger ujoints are the same size as a D44 so not exactly weak. It's no D60 but is decent axle for what it is. Link to comment Share on other sites More sharing options...
CJ's MJ Posted March 9, 2015 Author Share Posted March 9, 2015 That's great to hear. I couldn't get my cover off differential yesterday. PO painted it and bolts are stuck. I didn't have the time to remove parts to get a decent sized cheater attached to break them free. Link to comment Share on other sites More sharing options...
