Crist Clapper Posted February 21, 2015 Share Posted February 21, 2015 So... Why all the empty-space inside my clock? Am I missing an option? Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 21, 2015 Share Posted February 21, 2015 Most all of the various clocks used throughout the years have empty space in them. The only ones I seen full are the Sentinel modules, an option on the XJ Waggys. I used the space in mine to put in an ambient temp display HERE. Link to comment Share on other sites More sharing options...
Crist Clapper Posted February 21, 2015 Author Share Posted February 21, 2015 Excellent idea! Most all of the various clocks used throughout the years have empty space in them. The only ones I seen full are the Sentinel modules, an option on the XJ Waggys. I used the space in mine to put in an ambient temp display HERE. Link to comment Share on other sites More sharing options...
Crist Clapper Posted February 21, 2015 Author Share Posted February 21, 2015 Sentinel/Sentry: Link to comment Share on other sites More sharing options...
AeroNautical Posted February 22, 2015 Share Posted February 22, 2015 Wait a minute, they had to have a sensor in each of those components to read where the fluid level was? And I can't even begin to imagine how it knows if your brake pads are good. All that extra wiring! Link to comment Share on other sites More sharing options...
cruiser54 Posted February 22, 2015 Share Posted February 22, 2015 Wait a minute, they had to have a sensor in each of those components to read where the fluid level was? And I can't even begin to imagine how it knows if your brake pads are good. All that extra wiring! It was a disaster!! Link to comment Share on other sites More sharing options...
Guest Posted February 24, 2015 Share Posted February 24, 2015 Sentinel/Sentry: I would love to see a video of the system doing a run-through check at start-up of all these sensors. I'm assuming the lights are green and red for "good and bad"? Link to comment Share on other sites More sharing options...
BlackBeast Posted February 24, 2015 Share Posted February 24, 2015 Most all of the various clocks used throughout the years have empty space in them. The only ones I seen full are the Sentinel modules, an option on the XJ Waggys. I used the space in mine to put in an ambient temp display HERE. Where did you get that ambient temp display at??? I would like 1 like that in my 91. Link to comment Share on other sites More sharing options...
Crist Clapper Posted February 24, 2015 Author Share Posted February 24, 2015 MAYBE someday I'll get mine to work... No promises! I found two used complete units and one NOS display-module. Link to comment Share on other sites More sharing options...
HOrnbrod Posted February 24, 2015 Share Posted February 24, 2015 Most all of the various clocks used throughout the years have empty space in them. The only ones I seen full are the Sentinel modules, an option on the XJ Waggys. I used the space in mine to put in an ambient temp display HERE.Where did you get that ambient temp display at??? I would like 1 like that in my 91. Click HERE. Link to comment Share on other sites More sharing options...
Guest Posted February 24, 2015 Share Posted February 24, 2015 MAYBE someday I'll get mine to work... No promises! I found two used complete units and one NOS display-module. I thought you only went for NOS on your FSJ's Crist. :yes: I used to browse IFSJA all the time and read through countless threads. Methinks I should scour the web for good deals on rare goodies like these. Link to comment Share on other sites More sharing options...
Crist Clapper Posted February 24, 2015 Author Share Posted February 24, 2015 I know... The NOS display didn't come with the associated wiring/controller. I'll won't tell anyone if you don't! :P MAYBE someday I'll get mine to work... No promises! I found two used complete units and one NOS display-module. I thought you only went for NOS on your FSJ's Crist. :yes: I used to browse IFSJA all the time and read through countless threads. Methinks I should scour the web for good deals on rare goodies like these. Link to comment Share on other sites More sharing options...
Boilermaker Posted February 24, 2015 Share Posted February 24, 2015 That's a pretty good score especially considering putting together a complete system is nearly impossible even with access to a donor XJ with the sentry system equipped. There are about a dozen sensors, which even if they did work are usually pretty brittle. Those sensors usually require special mounting points (threaded holes drilled into the axles or oil pan, special caps on reservoirs, etc.). All attached to two wiring harnesses, one that runs out the firewall alongside the main dash harness and a second that runs down the length of the frame. Link to comment Share on other sites More sharing options...
Crist Clapper Posted February 25, 2015 Author Share Posted February 25, 2015 I kinda get the feeling that the challenge may too much for me. But... At maybe at least... I won't have a blank-cover! ;) That's a pretty good score especially considering putting together a complete system is nearly impossible even with access to a donor XJ with the sentry system equipped. There are about a dozen sensors, which even if they did work are usually pretty brittle. Those sensors usually require special mounting points (threaded holes drilled into the axles or oil pan, special caps on reservoirs, etc.). All attached to two wiring harnesses, one that runs out the firewall alongside the main dash harness and a second that runs down the length of the frame. Link to comment Share on other sites More sharing options...
