When the engine was rebuilt the mechanic put the oil filter adapter pointed to rear of the engine.  It used to point up.
Now, when I change the oil, I have to crawl under the truck and reach up to get the OF off.  I cannot pull it out the top with the sender unit and wires in the way.  I have tried everything.
I see a bolt on the face of the OF adapter.  Can I loosen the bolt and rotate the OF adapter  back to its original position?  Will turn easily?  Is it threaded?  Is there a gasket or sealer on it?
Mine is.... But if you remove .....I would never take it off, for rotation or really any reason, without replacing the o-rings.
They are so cheap and one of those things that if you don't you'll surely nick it re-installing and
then a leak appears.
A simple search should get you plenty of "internet based assistance".
Sloride, that may solve the issue of crawling under the truck.  However, in its current location, it drips oil on the starter when I remove the OF.  Another reason to change its position.
You can loosen and rotate it. I just did this yesterday to get it out of the way to remove the engine mount bolt. Didn't have the O-rings so I just loosened it enough to rotate it out of the way, got my new mount in and rotated it back into place and tightened it. I has not leaked yet but I'll be getting a set of the O-rings just in case.
Thanks Fiat.  I was not sure what was holding it in place.  I now know its just a bolt and O ring.  On my next oil change I will rotate it.
  • 1 month later...
I have a similar question: After a long weekend of wrestling bolts, I am nearly ready to install a replacement motor that has been sitting on a stand for 3 weeks. It's a '98 and has the the filter pointed backwards. I think I would prefer it pointed up like you all have discussed. Can anyone confirm I can just loosen the bolt and rotate? Other threads have referenced a locating pin that needs to be filed off. Is that the case for me?
Thank you
