I'm doing the 4wd swap and picked up WJ lower control arms.
Has anyone used the upper control arms off of a WJ ? Will they work or just stay with my current ones ?
Its a 89 Comanche, 4.0, auto
Haven't used them myself and it would depend on the purpose of your MJ...
If you measure them from center bolt to center bolt, I am sure you will find they are the same length (since the lowers fit near perfectly)
and if So I would use them over the OE Crappy uppers if I were a short arm kit still but for you it may not be worth doing if your stock and plan on staying stock...
Thanks hornbrod. Will be getting them from guy I got the LCAs from.
It will be a DD but get some off road. Yes I looked at the uppers and thought those look so weak and it got me wondering if WJs would work.
