Best way to permanently bond wiring
^^^ What he said. I twist the ends together, half an inch is good, and solder. Then heat shrink. Trouble with soldering is vibration will break the wire at the solder joint. Heat shrink helps take care of that. get a copy AC 43.13-1A&2. Tells you every possible thing you would ever want to know about soldering. If it's good enough for A/C then it's good enough for Jeep.
Butt splices if done correctly would be fine for something unimportant like a stereo. Anything pertaining to the vehicle running should be soldered (lights, sensors, etc.). Ideally you'd want to solder and shrink-tube everything though if you have the skills.
I always would butt splice than heat shrink around important things like my trailer lights I have butt splice then heat shrieked, I'm guessing I should go back and solder it.
