ownedueasy Posted December 13, 2014 Share Posted December 13, 2014 Ok so my 91s manual steering box is shot. And was wondering what all would be needed to convert to power steering.. Just a power steering pump, new gear box and new belt and hoses? Link to comment Share on other sites More sharing options...
benjy_26 Posted December 13, 2014 Share Posted December 13, 2014 Pretty much. I'm using the set up out of a 94 ZJ in my 87 2.5. Link to comment Share on other sites More sharing options...
mnkyboy Posted December 14, 2014 Share Posted December 14, 2014 The pump should even fit the bracket thats already there. The 2.5l uses a remote fluid reservoir on the core support, the 4.0l pump has the reservoir mounted to it. Either will work but the 4.0l pumps reservoir may interfere with the factory air box setup. Link to comment Share on other sites More sharing options...
ownedueasy Posted December 15, 2014 Author Share Posted December 15, 2014 Is that 100% all I need? Checking before i head to parts yard. And the XJ steering boxes are the same correct? No different steering shaft or anything needed? Link to comment Share on other sites More sharing options...
Comanche County Posted December 16, 2014 Share Posted December 16, 2014 On 12/14/2014 at 1:06 AM, mnkyboy said: Either will work but the 4.0l pumps reservoir may interfere with the factory air box setup. Yup, I just converted a manual 87' 2.5L TBI MJ to power steering. My donor was a 95/96' 2.5L XJ from the JY. I tried using a 4.0 renix PS set up, it can be made to work but it will interfere with the airbox...if you ditched the airbox and used a cone type air filter I imagine it would work okay. You won't need the steering shaft. The boxes are the same length. Get the pitman arm. The manual pitman arm will not fit the PS box...its too small. Link to comment Share on other sites More sharing options...
mnkyboy Posted December 16, 2014 Share Posted December 16, 2014 The steering shafts are different but will interchange. The power one has a rubber dampener in it and the manual one doesn't. Link to comment Share on other sites More sharing options...
dasbulliwagen Posted December 16, 2014 Share Posted December 16, 2014 Don't use the ZJ pitman arm. It drops too far and will cause bump steer. You'll need an XJ MJ p/s pitman arm. Link to comment Share on other sites More sharing options...
