VIN 1J7FT26P5ML549924 Model Year 1991 Make Jeep Model Comanche Engine Type 3 Li I4 Body Pickup Regular Cab Style Various Fuel Gas Safety ACTIVE BELTS Driveline RWD Transmission     MPG 0 miles/gallon Wheelsize R15 in. Wheelbase 113 to 120 in. Overall Width 72 in. Overall Length 179 to 194 in. Overall Height 64 in. Vehicle Weight 0 Manufactured In TOLEDO ASSEMBLY #1: TOLEDO, OH
PICK-n-PULL Kansas City (12th St.)
Kansas City, Kansas 66105
  • 4 years later...
*C1 TRIM STYLE C1 - CLOTH && VINYL BENCH SEAT
-SA CHARCOAL
152 Zone 52-Kansas City
1AA U.S. Dealer Retail
ALA SE Decor Group
APA Monotone Paint
BAF 130 Amp Alternator
BCY 475 AMP BATTERY
BGA Power Front Disc/Rear Drum Brakes
CBA Straight Back Bench Seat
CKJ Black Vinyl Floor Covering
CUM Mini Floor Console
DBB All Manual Transmissions
DDQ 5-Speed Manual Transmission
DMF 4.10 Rear Axle Ratio
DRJ 175MM Rear Axle
EPE Engine - 2.5L Power Tech I-4 Cyl.
GAC Tinted Glass Windows
GBB Tinted Windshield Glass
GCB Front Door Tinted Glass
GEH Fixed Door Vent Glass
GRV Left Manual Mirror
GUA Open
HAA Air Conditioning
JAZ DO NOT USE - See JP, KA classes
JCA 85 MPH Primary Speedometer
K3Z STRIPE/BADGE/MOLDING/COLOR
KDP STRIPE/BADGE/MOLDING COLOR
KWA STRIPE/BADGE/MOLDING/COLOR
LAP Shift Indicator Warning Lamp
LBC Glove Box Lamp
LMA Halogen Headlamps
MB1 Black Front Bumper
MFF Black Grille
MHB Bright Windshield Moldings
MMC Rear Door Solid Window Insert
MMG Belt Moldings
MMJ DRIP TROUGH MOLDINGS - TYPE I
NAA Federal Emissions
NBK EVAP Control System
NF2 18.5 Gallon Fuel Tank
NMC Heavy Duty Engine Cooling
PB8 MIDNIGHT BLUE MET CC PRI PNT - HB8
QB8 SECONDARY PAINT
RA8 Delete Radio
SBA Power Rack and Pinion Steering
SCE Alcantara Wrap Steering Wheel
SFA Standard Duty Shock Absorbers
SGA Rear Shock Absorbers
TBC Compact Spare Tire
TBM Tire Carrier Winch
TNC P195/65R15 BSW AS Touring Tires
TZH Michelin Brand Tires
WJK 15X6.0 Styled Steel Wheels
WLY All Steel Wheels
XBS Pickup Box
YAA Build To U.S. Mkt. Specifications
YGE 5 Additional Gallons of Gas
Z01 Rear Spring Group I
Z1A GVW/Payload Rating
Z57 Left Front Spring Group Vii
Z76 Right Front Spring Group VI
Body Model TL61
Build Date 11/20/90
  • 1 year later...
