drase Posted November 6, 2014 Share Posted November 6, 2014 As soon as I turn it on the RPM's go up to 1200 and when I let off of the accelerator the truck won't slow down. I drove down my road with my foot off the accelerator and it never went under 10 mph. Any ideas whats wrong with it? Link to comment Share on other sites More sharing options...
88whitemanche Posted November 6, 2014 Share Posted November 6, 2014 Sounds the tps.... Readjust as per cruisers write-up #8...and you should be good and double check your intake manifold bolts to be sure non of your bolts are loose.... http://comancheclub.com/topic/36382-cruisers-renix-tips/ Link to comment Share on other sites More sharing options...
cruiser54 Posted November 7, 2014 Share Posted November 7, 2014 Sounds the tps.... Readjust as per cruisers write-up #8...and you should be good and double check your intake manifold bolts to be sure non of your bolts are loose.... http://comancheclub.com/topic/36382-cruisers-renix-tips/ Yes. Do Tips 1 through 5 FIRST. No shortcuts. Link to comment Share on other sites More sharing options...
