HP dana 30 rebuild
It's not hard if you know what you're doing. :) And since I don't, I pay people to do it. It requires special knowledge and tools.
Figure a couple hundred for a new R&P, a hundred for a master rebuild kit, which will have all the necessary bearings and seals. And I have friends that help me with the labor for another hundred.
If you have to take it to a shop, they'll probably charge you $300+.
Ive rebuilt a few of them. Setting the gears properly is the hardest part. You reall only need a dial indicator and a lot of patience to do it though. Must easier to do on a bench then it is to do under the vehicle.
