Front Coil Spring Bump Stops
You axle won't droop because many reasons, the track bar ends will bind and/or hit, the LCAs will hit on the coil buckets (trim this off, its useless),
and the steering will also eventually bind too.
You might be able to force some new coils in there, but it's probably best to unhook at least the track bar and the drag link.
While you're at it, cut the corners of the coil buckets off where the LCAs hit at full droop. This will give you another 3-4" of droop for on the trail.
You can rent some coil spring compressors, but be careful with them. If you're a dummy you can really get hurt.
you can unhook your lowers to put the springs in also.i had to do that on mine cause i exploded the cheap compressors i had. don't ask how that happened but lets just say don't buy cheap ones and use them ALOT without check them for the threads stripping out periodically. :oops:
Cole
