thedave360 Posted September 13, 2014 Posted September 13, 2014 I need some help from the MJ gurus. So far this problem had only plagued me on the trails but it happened to me the other day in traffic. Maybe heat related? I'm not sure. Anyway here's what it does.... After riding around a while, I get on the trails or in traffic (low speed or mostly stopped while idling) everything is fine unless I stop the engine for a couple minutes. When it cranks back up it doesn't want to idle smooth and will hesitate if I give it gas then it'll start suttering. The idle surges sometimes and it'll kill if I don't hit the gas to keep it alive. It will continue to do this unless I either 1) Turn it off and let it cool for 15-20mins or 2) Get up to highway speeds for a few minutes. Other notes on this... -The temp gauge says the engine isn't getting too hot when this happens. The aux fan doesn't even come on so I know its not getting too hot. -The voltage gauge reads low (right around 12) constantly when lights and AC and Aux fan are on. I've measured with a multimeter at the battery cables and its getting high 13's with all of the accessories on. -All sensors, fuel pump, fuel tank, fuel filter, fuel pressure regulator and fuel injectors are less than a year old -All aluminum 3 core radiator, and higher rpm fan clutch -This problems happened before I replaced everything too. Its gotten a little better, but its still a problem. Any advice would be much appreciated!
88whitemanche Posted September 15, 2014 Posted September 15, 2014 If you haven't already done this... http://comancheclub.com/topic/36382-cruisers-renix-tips/
thedave360 Posted September 15, 2014 Author Posted September 15, 2014 If you haven't already done this... http://comancheclub.com/topic/36382-cruisers-renix-tips/ Interesting. Mine's a 92 so it isn't renix but I'll give it a shot.
ggcnash Posted September 15, 2014 Posted September 15, 2014 Some, not many of those apply to us H.O guys. Check fuel pressure at rail while this is happening, to be sure your able to do this go to the DIY forum and look up Hornbrods permanent fuel pressure gauge. Honestly one of the best mods I've done. Then diagnose from there, but that is good starting point. Let us know how it goes
thedave360 Posted September 16, 2014 Author Posted September 16, 2014 Some, not many of those apply to us H.O guys. Check fuel pressure at rail while this is happening, to be sure your able to do this go to the DIY forum and look up Hornbrods permanent fuel pressure gauge. Honestly one of the best mods I've done. Then diagnose from there, but that is good starting point. Let us know how it goes Nice. I'll try that too. I wanted to do that anyway, thanks for pointing me in the direction of a good writeup.
HOrnbrod Posted September 16, 2014 Posted September 16, 2014 I had that same problem on my 91 especially on hot summer days when stopping and shutting down for a few minutes. When starting back up I'd get long cranks before it fired up, then rough idling for a bit. Sometimes it wouldn't fire at all so like you I'd let it sit for 15 minutes then it started right up. I figured IAT sensor heat might be the cause. What I did was pickup a new IAT sensor, drilled and tapped a new hole (1/8 NPT) and mounted for it in the cold air intake. I left the original IAT in it's stock location on the intake manifold. So in the summer I plug into the CAI tube; in winter it goes back to the stock manifold location. It required extending the IAT harness a few inches to reach the new location. It cured the long crank times and rough idling for me.
thedave360 Posted September 16, 2014 Author Posted September 16, 2014 Assuming I don't have such a sweet CAI on mine at the moment, I should be able to do the same thing on the stock intake box...right? Like on the neck where the box transitions to the tube is what I'm thinking.
HOrnbrod Posted September 16, 2014 Posted September 16, 2014 Yes, that's a good location. It has to be like 80-100 degrees cooler than the intake manifold.
thedave360 Posted September 16, 2014 Author Posted September 16, 2014 whats the problem that it causes? Does the temp being too high cause a lean or rich condition or something?
HOrnbrod Posted September 16, 2014 Posted September 16, 2014 http://www.angelfire.com/my/fan/IAT_sensor.html
