Rough Country 4.5" install
Soak the stuff a couple of times for a couple of days with PB blaster.
Pull it in front of your garage before lifting it. Mark where you front tires are. Turn on headlights on. Place a piece of tape where the brightest spot is. After your lift put the truck in the same spot and adjust you headlights to hit that same spot.
While you have things apart check the TRE on the body side. Check the mounting hole in the bracket to make sure it isn't wobble out. These two things are often cause of DW so check while you have it part
TRE??
