gear ratio
Nope.  that's perfectly normal in axles.  because of differing axle sizes, the ring gear size change and the tooth count changes.  manufacturers just get the ratios close enough to work.  the difference between a 3.55 and a 3.54 is smaller than the difference in tire diameters.  :thumbsup:
there are limits though.  4.09, 4.10 and 4.11 are all considered the same ratio.  but, for example, mix a 4.10 with a 4.30 and problems will happen.
This helped a lot I have 4.10 gear ratio in my front D30 and rear D35 and I'm looking for a ford 8.8/Dana 44 and I've found one with a 4.09 gear ratio, so this will work with no issues?
Join the conversation
You can post now and register later. If you have an account, sign in now to post with your account.
Guest
Reply to this topic...
×   Pasted as rich text.   Paste as plain text instead
  Only 75 emoji are allowed.
×   Your link has been automatically embedded.   Display as a link instead
×   Your previous content has been restored.   Clear editor
×   You cannot paste images directly. Upload or insert images from URL.
