HOrnbrod Posted August 20, 2014 Share Posted August 20, 2014 The right axle shaft in a Dana 44 is 1/2" longer than the left side. Why? Link to comment Share on other sites More sharing options...
yxmj Posted August 20, 2014 Share Posted August 20, 2014 I think if you take a tape to it you will find the pinion is a bit off set..( not perfectly centerd)....that would make the ring off set and by defaut the carrier...so one shaft is longer. . :MJ 1: . That might not make sence but i think you will get my drift? Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 20, 2014 Author Share Posted August 20, 2014 Let me rephrase: What wasn't the the D44 (and some other axles like the AMC 20) diff housing designed to be centered so the axles could be of equal length and swap-able / interchangeable? Link to comment Share on other sites More sharing options...
Eagle Posted August 20, 2014 Share Posted August 20, 2014 That would have been too easy, and too logical. Remember, it WAS AMC we're discussing. As much as I liked AMC vehicles, they did some strange things. However, in all honesty, it may not have been an AMC decision at all. It may have been Dana Spicer. Link to comment Share on other sites More sharing options...
yxmj Posted August 20, 2014 Share Posted August 20, 2014 I do not know it would make things easier.....if I remember right some 44's (maybe on Scouts) were even more off set....like (I could be wrong) 1.25"-1.5" Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 20, 2014 Author Share Posted August 20, 2014 I was just curious if there was a some design reason for it. Link to comment Share on other sites More sharing options...
Incommando Posted August 20, 2014 Share Posted August 20, 2014 The Dana 44 far precedes AMC. Looking around there are at least as many axle assemblies with uneven shafts as not. Link to comment Share on other sites More sharing options...
