Careful you might ask a question not asked,, :doh: ,,,since you singed up try the search bar... :dunno: ...or the Comanche tribe from the past has told me of the " Google" though I don't believe in it....
With the GM v6 other options are available bit they won't just be bolt in and go. If you need to get it going just find another 2wd ax5. If you're wanting to go 4wd now then find a 4wd donor and get it all together like was said. You'll still have driveshaft issues unless you find another 86 mj donor or a later 2.5 long bed. So do your homework before buying stuff peicemeal. Good luck and let us know how it turns out.
