Jeepman55 Posted August 19, 2014 Posted August 19, 2014 I have a 5 speed transmission on a 1986 Comanche , 2.8 v6 that isn't working, is there another transmission that will fit?
Jeep Driver Posted August 19, 2014 Posted August 19, 2014 You have an AX5 and you'll need another one.
Jeepman55 Posted August 19, 2014 Author Posted August 19, 2014 I guess I would like to know if I can use something else the Comanche is 2 wd I would like to make it 4x4 if its going to be a pain then yes I need one
yxmj Posted August 19, 2014 Posted August 19, 2014 Careful you might ask a question not asked,, :doh: ,,,since you singed up try the search bar... :dunno: ...or the Comanche tribe from the past has told me of the " Google" though I don't believe in it....
Jeep Driver Posted August 19, 2014 Posted August 19, 2014 I would suggest you find a XJ with a 2.5 for the bell, trans, transfer case swap. Look for the 94+ years. You'll have to do your homework on the flywheel/clutch/pilot bushing/bearing.
dasbulliwagen Posted August 19, 2014 Posted August 19, 2014 With the GM v6 other options are available bit they won't just be bolt in and go. If you need to get it going just find another 2wd ax5. If you're wanting to go 4wd now then find a 4wd donor and get it all together like was said. You'll still have driveshaft issues unless you find another 86 mj donor or a later 2.5 long bed. So do your homework before buying stuff peicemeal. Good luck and let us know how it turns out.
Jeepman55 Posted August 19, 2014 Author Posted August 19, 2014 what other options are there? I already have the diffs and transfer case 231 out of 2000 will the trans out of a S10 4x4 work?
Jeepman55 Posted August 20, 2014 Author Posted August 20, 2014 what other trans options are there I really won't to go 4x4 I have both diffs out of a 2000 and transfer case will a s10 trans work
Jeep Driver Posted August 20, 2014 Posted August 20, 2014 TH350 out a 4x4 Blazer and a Novak adapter to the TC. No computer and will bolt to your 2.8 Or look to the NV3350 You really got something against the AX5 don't you?
Jeep Driver Posted August 20, 2014 Posted August 20, 2014 Another option you have is the Dakota 2.5 to AX15 bell housing and then an AX15 and TC out of a XJ or MJ. They are hard to come by......Check here.....I remember a member saying he had one he'd sell.
dasbulliwagen Posted August 20, 2014 Posted August 20, 2014 What are you looking to do with this, and again, why are you so averse to the AX5?
Jeepman55 Posted August 20, 2014 Author Posted August 20, 2014 Not adverse to the AX5 just they are hard to find...Just thought that maybe something more plentiful would work...
