redwolf624 Posted August 8, 2014 Share Posted August 8, 2014 i actually got a roll bar for a long wheel base comanche, it's mounted just like the short wheel base one and not from front to rear of the bed but i was wondering do all roll bars have back plates for mounting or just bolted to the bed, i just have the bar itself no bolts, no mounting hardware at all. i just want to mount it right for when i do bolt it in, Redwolf Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted August 8, 2014 Share Posted August 8, 2014 Both the lwb and swb use the same bracketry. Backing plates having 3 m10 x1.5 nuts with bolts are used at the front of the wheel well and brackets mount to the frame using 6 m10x1.5 bolts on each side . Link to comment Share on other sites More sharing options...
redwolf624 Posted August 8, 2014 Author Share Posted August 8, 2014 Both the lwb and swb use the same bracketry. Backing plates having 3 m10 x1.5 nuts with bolts are used at the front of the wheel well and brackets mount to the frame using 6 m10x1.5 bolts on each side . ok, i wasn't sure if i needed a backing plate, i don't know if they have to be a special size so i'm havin them made the same size as the base at the end of the pipes, Redwolf Link to comment Share on other sites More sharing options...
Strokermjcomanche Posted August 8, 2014 Share Posted August 8, 2014 I can snap some pics of them and send them to your email . But I think on the the informational picture thread there is a picture of what the brackets look like. Link to comment Share on other sites More sharing options...
HOrnbrod Posted August 8, 2014 Share Posted August 8, 2014 Make your own: http://comancheclub.com/topic/41054-sometimes-you-just-roll-bar-brackets/?hl=roll+bar+brackets Link to comment Share on other sites More sharing options...
redwolf624 Posted August 8, 2014 Author Share Posted August 8, 2014 Make your own: http://comancheclub.com/topic/41054-sometimes-you-just-roll-bar-brackets/?hl=roll+bar+brackets that's what i'm havin done, my dad works in a metal shop, he's just waitin for the steel shipment, Redwolf Link to comment Share on other sites More sharing options...
cbreiter Posted August 14, 2014 Share Posted August 14, 2014 I just picked a roll bar up, and set it in the box, to see how it looked. Guess I need to make some brackets too now, lol Link to comment Share on other sites More sharing options...
