jpdriver1 Posted July 20, 2014 Share Posted July 20, 2014 I might have missed this in my search, but is anyone using a dishwasher as a parts washer? thanks Link to comment Share on other sites More sharing options...
JeepcoMJ Posted July 20, 2014 Share Posted July 20, 2014 You won't be putting dishes back in it i assume Link to comment Share on other sites More sharing options...
jpdriver1 Posted July 20, 2014 Author Share Posted July 20, 2014 no this is to be outside in the shop area ---- :thumbsup: Link to comment Share on other sites More sharing options...
Comanche County Posted July 20, 2014 Share Posted July 20, 2014 I think you be better off finding a used parts washer or getting a cheaper harbor freight version. That way you're not running an extra hot water line in the garage for a dishwasher, also I doubt a regular dishwasher will get hot enough to deal well with the build up of grime on auto parts. Also it won't be able to reach into small hard to get to areas on parts. Since the water is sprayed from the bottom, you'd get a clean bottom of the part, then the top will still have "cleaned" grime on it. Not that bad in theory, I just don't think it'll work all that well. Link to comment Share on other sites More sharing options...
jpdriver1 Posted July 20, 2014 Author Share Posted July 20, 2014 pretty much what I've been thinking also --- thanks - will most likely scrap this unit -- Link to comment Share on other sites More sharing options...
Comanche County Posted July 20, 2014 Share Posted July 20, 2014 edit:::delete... :thumbsup: Link to comment Share on other sites More sharing options...
Mattwheels Posted July 21, 2014 Share Posted July 21, 2014 Although, if you could plumb the dishwasher to pull from a tank of hot solvent it could work pretty decently, just bottom rack everything :P just make sure everything is non-flammable. Link to comment Share on other sites More sharing options...
