drase Posted June 8, 2014 Share Posted June 8, 2014 I can't turn the key all the way back in electric only mode AND now when I turn the truck off it doesn't want to click back so I can get the key out. When I do turn it back there is a crack like sound. Anyone know what the problem might be and how to fix it? Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted June 8, 2014 Share Posted June 8, 2014 Ignition cylinder is about to give up the ghost. Time you replace it. Link to comment Share on other sites More sharing options...
drase Posted June 8, 2014 Author Share Posted June 8, 2014 If I get a new ignition cylinder do I have to have a new key made to fit it? Link to comment Share on other sites More sharing options...
jimoshel Posted June 8, 2014 Share Posted June 8, 2014 Usually the key comes with the cylinder. Try spraying the old cylinder with a shot of graphite first. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted June 8, 2014 Share Posted June 8, 2014 If I get a new ignition cylinder do I have to have a new key made to fit it? Yea, it will come with a new key. Try the graphite suggestion that Jim suggested to get the current key out. I'd still recommend replacing the cylinder before too long. http://www.rockauto.com/catalog/moreinfo.php?pk=951083&cc=1181483 Link to comment Share on other sites More sharing options...
Co-MAAAN-cheee Posted June 8, 2014 Share Posted June 8, 2014 I had a similar issue and very much double its the cylinder in your case. It was the shift ignition interlock. Google those three words and you find a bunch of useful info. I thoroughly cleaned the cable by spraying wd40 through the cable and problem solved. Link to comment Share on other sites More sharing options...
drase Posted June 8, 2014 Author Share Posted June 8, 2014 I had a similar issue and very much double its the cylinder in your case. It was the shift ignition interlock. Google those three words and you find a bunch of useful info. I thoroughly cleaned the cable by spraying wd40 through the cable and problem solved.[/ Where is the cable? Is it in the center console? My search results keep pulling up the ignition cylinder where the key goes and a ignition switch on top of column under the dash. I don't see any mention of a cable. Link to comment Share on other sites More sharing options...
onlyinajeep726 Posted June 8, 2014 Share Posted June 8, 2014 The shift lock cable he's talking about refers to those with an automatic transmission. It connects to a lock lever inside the steering column that unlocks the shifter when the key is turned to the "unlock" position. If you have a manual, ignore this. Link to comment Share on other sites More sharing options...
Co-MAAAN-cheee Posted June 8, 2014 Share Posted June 8, 2014 thank for clarifying. Btw - I clicked the link to his rig and saw it was automatic before answering. Google these exact words 'ignition shift interlock cable jeep Cherokee' read the first three links Link to comment Share on other sites More sharing options...
drase Posted June 8, 2014 Author Share Posted June 8, 2014 Ok, this helps cause I have a automatic. Link to comment Share on other sites More sharing options...
drase Posted June 9, 2014 Author Share Posted June 9, 2014 I had a similar issue and very much double its the cylinder in your case. It was the shift ignition interlock. Google those three words and you find a bunch of useful info. I thoroughly cleaned the cable by spraying wd40 through the cable and problem solved. thank for clarifying. Btw - I clicked the link to his rig and saw it was automatic before answering. Google these exact words 'ignition shift interlock cable jeep Cherokee' read the first three links Just to be clear did u remove the center console also when u lowered steering column when u got the cable out? Link to comment Share on other sites More sharing options...
JeepcoMJ Posted June 9, 2014 Share Posted June 9, 2014 Either shift lock cable issues for auto, or lockout for manual. Mechanism is in the column. Also, partially fried ignition switches can do that...two bolts to remove from the top side of the column near the firewall. Pull it off first and see if the lock moves smoothly. If it does, that is your issue. Link to comment Share on other sites More sharing options...
Co-MAAAN-cheee Posted June 9, 2014 Share Posted June 9, 2014 I never removed the cable. I removed the lower part of the dash and was able to get wd40 into the column end of the cable. I did this when I was restoring the interior so I had everything except the dash out already. I also cleaned the mechanism on the shift portion of the interlock assembly. You might try taking off the cowling around shifter and inspect the assembly while shifting in and out of part. There is a notch at park that a pall has to drop into before the interlock will release the key. Keep in mind my experience is limited. The links I sent to you have some very experienced advice. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted June 9, 2014 Share Posted June 9, 2014 check ignition switch first. Easiest to do, likely cause Link to comment Share on other sites More sharing options...
drase Posted June 10, 2014 Author Share Posted June 10, 2014 Checked ignition switch by taking it off of column and cylinder would still get stuck from going back from Run to On. Gets stuck in On position and have to pull interlock cable on column toward me to have key go back to Lock. So don't think its the ignition switch. Also, the truck will not start at all. Brand new battery in it too. ADJUSTMENT - BRAKE TRANSMISSION SHIFT INTERLOCK CABLE (1) Shift transmission into PARK. (2) Remove shift lever bezel and console screws. Raise bezel and console for access to cable. (3) Pull cable lock button up to release cable. (4) Turn ignition switch to LOCK position. (5) Use a spacer to create a one millimeter gap between the shifter pawl and top of the shift gate. (6) Pull the cable forward and release.Ensure the cable end is seated in the bellcrank and press cable lock button down until it snaps in place. (7) Check adjustment as follows: (a) Check movement of release shift handle button (floor shift) or release lever (column shift). You should not be able to press button inward or move column lever. (b) Turn ignition switch to RUN position. © Shifting out of park should not be possible. (d) Apply the brake and attempt to shift out of PARK. Shifting should be possible. (e) While the transmission is shifted out of PARK, release the brake and attempt to shift through all gears. Release the shift button at least once during this procedure. The ignition key should not go to the LOCK position. (f) Return transmission to the PARK position without applying the brake. (8) Move shift lever back to PARK and check ignition switch operation. You should be able to turn switch to LOCK position and shift lever release button/ lever should not move. Does anyone have a pic of the interlock cable adjustment button? I don't know where it is. Link to comment Share on other sites More sharing options...
Co-MAAAN-cheee Posted June 15, 2014 Share Posted June 15, 2014 I have you solved the problem? Link to comment Share on other sites More sharing options...
drase Posted June 16, 2014 Author Share Posted June 16, 2014 No, I haven't. Don't know where interlock cable adjustment button is. But, truck won't start at all now either. I called my mechanic and when this happened b4 he replaced the ignition switch. Going to tow it to him today. Wife needs MJ out of her garage p spot. Link to comment Share on other sites More sharing options...
drase Posted June 25, 2014 Author Share Posted June 25, 2014 It was a plastic ring in the column that had gotten stripped, my mechanic replaced it and it is fine. I did not get the exact name as I and he were both in a hurry when I picked it up. Nothing to do with shift interlock or ignition switch. Link to comment Share on other sites More sharing options...
