Spectormj Posted June 2, 2014 Share Posted June 2, 2014 my 86s gas gauge reads correct only when my truck is off Is that a bad wire or a bad float? if its the float how hard of a fix do i seem to be facing and will any new float work or no? It sucks trying to prep for trips and not knowing if ive got enough gas Help me out Link to comment Share on other sites More sharing options...
yxmj Posted June 2, 2014 Share Posted June 2, 2014 Best guess to check the float.......jack up the front and back ....or park on a severe incline (front and back) and see if your gauge moves....... Link to comment Share on other sites More sharing options...
Spectormj Posted June 2, 2014 Author Share Posted June 2, 2014 on a full tank or almost empty? Link to comment Share on other sites More sharing options...
yxmj Posted June 2, 2014 Share Posted June 2, 2014 1/2 ?? Link to comment Share on other sites More sharing options...
Spectormj Posted June 2, 2014 Author Share Posted June 2, 2014 ok ill try that but ive only got my high lift jack.. If i were to swap out for a new tank with all the parts would it maybe fix one but leave the other Link to comment Share on other sites More sharing options...
jimoshel Posted June 2, 2014 Share Posted June 2, 2014 Remove the sending unit from the gas tank. It can be done without dropping the tank. With the wire hooked up and the ign sw on, move the float up and down. What does the gauge do? Link to comment Share on other sites More sharing options...
johnj92131 Posted June 2, 2014 Share Posted June 2, 2014 Like Jim said, just pull the sender from the tank and check it that way. You should see the contact that moves over the coil/resistor. Make sure it is making contact over the full range of float movement. Link to comment Share on other sites More sharing options...
jimoshel Posted June 2, 2014 Share Posted June 2, 2014 And yes. Make sure the gas level in the tank is below the hole. 1/2 tank or less. Link to comment Share on other sites More sharing options...
Spectormj Posted June 2, 2014 Author Share Posted June 2, 2014 Thank Jim my next question on that is will i have to lift my bed off to get to the sending unit? Link to comment Share on other sites More sharing options...
jimoshel Posted June 2, 2014 Share Posted June 2, 2014 NO. There is enough room to get to it. The drive shaft makes it a little crowded but there is enough room with out dropping the tank or the shaft. Link to comment Share on other sites More sharing options...
Spectormj Posted June 2, 2014 Author Share Posted June 2, 2014 rockin cause ive got the roll bar in the bed and I'm betting the bolts to pull it are stuck with a lot of rust and dirt So pull the sender and move the float I'm guessing have the gf or someone in the cab to watch the gauge Link to comment Share on other sites More sharing options...
jpdriver1 Posted June 2, 2014 Share Posted June 2, 2014 would suggest getting a new gasket before removing the locking ring --- Link to comment Share on other sites More sharing options...
Spectormj Posted June 3, 2014 Author Share Posted June 3, 2014 ok ill tear into it sometime this weekend if I'm not asleep or at the CMA Fest Link to comment Share on other sites More sharing options...
