Idiot Lights
Hoping this will be an easy question to answer and an easy problem to fix . So I have the idiot light cluster. And aren't all the lights for warning bulbs supposed to illuminate when the key is switched to on? When I do it only the oil and battery light come on. The temperature light doesn't come on. I replaced the bulb thinking it was burnt. But it's not the case. Will replacing the temperature sensor fix that? Or is there a disconnected electrical wire?
Just a guess but the lights would signal......low oil pressure......no or high battery voltage......overheating....
So with a cold motor you would have....no oil pressure (light on) no power (light on)....motor under overheating (light off)
?????????????????????? . :MJ 1: .
I'm not sure. Maybe so. I just figured like in any other car when you turn the switch before you start the engine all warning lights turn on to do a test to see all light come on and then once started turn off?
A 1988 car or older?????????
I just noticed this on mine the other day.  Key on, not running, oil and volts light up as a test (I assume).  After I fire it up, the water temp light comes on for a second and then goes off.... again i assume as a test?
  • 9 months later...
