Need Help Removing Bump Stops
You are gonna need a spring compressor to pull out the coils, you can rent one from most auto parts stores. They are a b*tch to use, but its the only thing i can thing of that can do it. As for what to use to remove the bump stops, I used a big ole pipe wrench to loosen mine.
Not mine, but it should give you a good idea of where to put the pipe wrench.
5075d1272917375-bump-stop-removal-lktfbu
FPC
I recently replaced my bump stops as they were dry rotted and falling apart. It's easy-peasy if you jack up one side at a time and let everything hang. Off/ On with big channel locks. Use a crow bar between a pair of coils to open them up a bit and slide the old bump stops out and the new ones in.
