54bobby Posted May 13, 2014 Share Posted May 13, 2014 hey guys, when i go into a low speed turn, like pulling out of a driveway, the steering feels like it wants to turn further than i want it to then it backs off. it's like a back and forth feeling. in the past year i have put on new ti rods, track bar, steering stabilizer, and sway bar links. any ideas?? Link to comment Share on other sites More sharing options...
banshee Posted May 13, 2014 Share Posted May 13, 2014 Have it aligned sounds like mine before alignment Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 13, 2014 Share Posted May 13, 2014 Yep, sounds like your caster is AFU (too negative). Link to comment Share on other sites More sharing options...
54bobby Posted May 13, 2014 Author Share Posted May 13, 2014 had it aligned when i installed the suspension parts. hit no large holes or curbs. could it be out already? Link to comment Share on other sites More sharing options...
Jeep Driver Posted May 13, 2014 Share Posted May 13, 2014 Don't assume that new parts are good parts. Check your track bar again. I have my fifth one in 2 years now. Link to comment Share on other sites More sharing options...
HOrnbrod Posted May 13, 2014 Share Posted May 13, 2014 Got an angle finder? Stick it on top of the L & R upper ball joints and check your caster while sitting on level ground. Link to comment Share on other sites More sharing options...
banshee Posted May 14, 2014 Share Posted May 14, 2014 What's the caster supposed to be?? Link to comment Share on other sites More sharing options...
Minuit Posted May 14, 2014 Share Posted May 14, 2014 Factory spec is +7.5 deg. The FSM states that acceptable range is between +7 deg. and +8 deg. Keep in mind that these are for stock trucks. Link to comment Share on other sites More sharing options...
