comancheman Posted April 30, 2007 Share Posted April 30, 2007 do they strip commonly or is this an indication of another internal problem? Link to comment Share on other sites More sharing options...
Pete M Posted April 30, 2007 Share Posted April 30, 2007 You mean the little plastic gear? Maybe your speedo cable is binding or sticking? :dunno: Link to comment Share on other sites More sharing options...
partsmj Posted April 30, 2007 Share Posted April 30, 2007 If you remove it from the trans, it has four different ways to put it back in, depending on the size of the gear. You should notice it is offset. It usually takes me a couple of tries to get it right. Link to comment Share on other sites More sharing options...
JeepcoMJ Posted April 30, 2007 Share Posted April 30, 2007 If you remove it from the trans, it has four different ways to put it back in, depending on the size of the gear. You should notice it is offset. It usually takes me a couple of tries to get it right. that's only true if it's got a np231 transfer case....my 207 can only go in and snug down one way. as for it going bad, it's just like any other gear...it can go bad if it doesn't have anough lube or if it's hammed on. check speedo cable for binding, which is unlikely, and check tcase for fluid. also be sure it's the right gear Link to comment Share on other sites More sharing options...
comancheman Posted May 1, 2007 Author Share Posted May 1, 2007 yeah i noticed the offset, how do i know which way is the right way? Link to comment Share on other sites More sharing options...
comancheman Posted May 1, 2007 Author Share Posted May 1, 2007 nvr mind apparently it says the number of teeth on the gear housing and you align it with the dimple on the tcase Link to comment Share on other sites More sharing options...
